After driving my 91 and parking it I can smell a little gasoline. Any advice on where to look for a leak? It doesn't appear to be gushing out anywhere. Since buying it I have done nothing to the fuel system but change the filter. Thanks.
Gasoline odor
Check the vent line, it'll go from the charcoal canister to the tank and I once had the metal line on the tank rot off it, it might be your problem
^ don't forget the fuel pressure regulator o-ring while checking injectors.
If you get the gas smell bad in the back seat check the evap hoses tucked behind the rear fender. Those hoses get crunchy after 20 years and you'll smell it on hot days.
Sent from the bathroom via crapatalk.91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
92 L 5sp "Red" RIP
95 Grand Prix SE DD
Wife's Stuff:
89 L 5sp "Carby Car"
97 Aspire auto "Pink Panther" Build Thread
Spring 2013 IndyStiva:
http://www.fordfestiva.com/forums/sh...eet-April-20th
The rubber gasket between the fuel pump lid/cover and the gas tank on my car is not a perfect seal. If I fill it right to the brim the smell of gas is evident inside the car. This lid is underneath another metal cover which is inside the car and under the back seat. Slitting the carpet is fastest way in there. All Philips screws, small hose clamps and one electrical connector to undo.
