On my 89 Carb Festy, my O2 Sensor is disconnected. There is a wire coming from the sensor but someone cut the rest and we can't find where it goes. I need to know where the rest of the wire goes. Anyone know? Any pictures that would help?
O2 Sensor
O2 Sensor
Harrison M.
motobase8@yahoo.com | 91montero4x4@gmail.com
1989 Festiva Hatchback L 4 spd (project tuner)-33 MPG
1991 Mitsubishi Montero 4x4 (offroader)-14 MPG
1971 Datsun 240z (in restoration)
1966 Ford Falcon (restored)
Driving is a passion.
I know nothing about the 'anomaly 89s' but if they have an 02 sensor then it would be prudent to try to hook it back up. Regulated car manufacturers don't build stuff on to a car for no reason. And I doubt that 02 sensors were an option or accessory at the time.
Right beside the dip stick, a long fluted white plastic connector attached to the lower end of the bracket with the hole in the top which I assume is for lifting the engine out of the bay.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by milehighbear View PostIm lost, why would a carby have an 02 sensor. They are for EFI cars. I think someone replaced your exhaust pipe with one that had an o2 sensor in it and thats why it is not hooked up. Course I could be wrong. Wife tells me only time I'm right is when i say i am wrong.
Disclaimer - I know absolutly nothing about the octopus thing they call the Feedback carb, so I could be full of it. LolMike Holmgren
Thief Rvr Fls, MN
1989 Festiva L, carb. 4 spd.
"If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
Almost all cars sold in the US with carburetors after 1981 have a computer with
feedback from o2, temps, tps, baro and vacuum. They use internal electronics
like how an injector works to control the fuel mix almost as quick and accurate
as injection. The main reason they lost out is the long intake runners coated
with liquid fuel had higher emissions. TBI might have been slightly more durable
but the big injectors running 4 cylinders were not durable at all compared to PFI.
So TBI is a museum piece now too.Reflex paint by Langeman...Lifted...Tow Rig
The O2 sensor is used to indicate the amount of unburnt fuel in the exhaust gas which the computer attempts to correct by altering the air/fuel mixture entering the cylinders. The optimal air/fuel ratio for complete combustion is 14.7/1 if I remember correctly. Feel free to look it up. I think on EFI models the computer also advances the timing but not on carburetted models.
My carburetted model has 116k km, original O2 sensor and catalytic converter, and passes the emissions test every 2 years with flying colours. Only problem has been rising NOx which was corrected by cleaning the EGR valve.Last edited by WmWatt; 08-01-2012, 08:51 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I believe the single wire from the O2 sensor is suspended from the top of the front rad support and travels all the way back to the ECU. The wire color is yellow with a green stripe. It terminates at the large center connector of the ECU.Last edited by bravekozak; 08-01-2012, 09:09 PM.
Originally posted by Bert View PostI know nothing about the 'anomaly 89s' but if they have an 02 sensor then it would be prudent to try to hook it back up. Regulated car manufacturers don't build stuff on to a car for no reason. And I doubt that 02 sensors were an option or accessory at the time.Harrison M.
Originally posted by 500dollarfestiva View PostI know that's why I'm trying to see. If your not going to help then why bother.
