I have a 89L. I noticed the secondary barrel looked as if it had not opened in a long time. When I tried to move it my hand, it was froze solid. I used carb cleaner on the shaft and down the barrel to remove all the build up. Now I am able to easily move the butterfly plate by hand.
I see the vacuum diaphragm that can move the secondary open. However, I see no other way for it be be opened. No link to the primary at all. Only a steel cam on the primary shaft that forces it closed under about half throttle.
Now finally to the questions. What all should be acting on it? Am i missing a piece? Any ideas on a repair?
Thanks for your time folks.
