headlights/tailights wont come on and relays buzz really loud when I attemptto turn the lights on, any ideas? Would a bad ground do this? Or an accidental polarity mix up in the wiring?
Missing a ground. Probably a ground block, which has more than 1 ground. There are only 3 grounds on the body harness, driver headlight area, passenger headlight area, then inside the cab under the dash. These are the main grounds for the car. Make sure you have the main ground from the engine block to the body.Last edited by Flyin4stroke; 08-09-2012, 04:42 AM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
You were correct! when I relaocted the harness I didn't anchor one of the ground blocks back down. Headlights now work perfect. Taillight running lights are still not coming on yet, brake lights do work, but that could be bulbs fuses, etc.Originally posted by Flyin4stroke View PostMissing a ground. Probably a ground block, which has more than 1 ground.
Thanks!'93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
