auto festi 1.3 efi engine, into manual festi efi?
  • auto festi 1.3 efi engine, into manual festi efi?
    what things should i be concerned about if any besides the sensors wich i can switch over, i dont know wich ones, i suspect that would be the only difference?
    1989 Miitsubishi Mirage turbo RS, 4G61T, smic, 3"S.S. 13g, EBC,
    89 LX carb Festy, 5spd, 106xxxkms, 2nd owner.
    ........Let boost be with you
    and bring some timing too........
    no one, knows of anything that will be a possible problem?
    the auto is a 1990, and the manual is a 1993.
    oh one thing thats puzzling me is the nut securing the axle on the drivers side to the hub is really stubborn, i have an impact wrench, and that still didnt loosen it, is it clockwise to loosen or somthin like the rear passenger spindle nut?, ive broken a wrench with a breaker bar trying to loosen it, if i cant get it off i think ill have to leave the tranny in the engine bay when i lift the motor. any suggestions?
      can you rephrase the question?
      you want to put an automatic transmission into a manual equipped festy?
      or the other way around, man into a automatic equipped festy?
        I think he wants to use an engine from a auto tranny car in a man tranny car.
        93 GL modyfied!!!
        :fish:
          if that's the case,
          you will need to swap separation plates, to the manual transmission
          lose the starter mounting bracket
          and find a vacuum hose plug , to plug off the one line that went to the automatic trans
          as far as know, the sensors on either engine are exactly the same
          and as far as the spindle nut is concerned, you will need to un-stake the nut before taking off the regular left hand threaded nut
            sorry for the confusion. im taking a motor from an auto festy, and putting it in a manual festy.
            whast the best way to unstake the nut? the stubborn one on mine is punched in so much that i canit get anything under it to pry up on, is there a trick or a special tool you use?
            thanks for the help.
              I use a center punch to unstake the nut.
                got the auto motor pulled yesterday, gonna pull the 5spd today and do the switch,
                do you mean swap the separation plate from the 5spd tranny to the new motor(originally auto), and the starter mounting bracket? wich bracket is that as there are a few connected to the starter.
                Thanks for the help.
                  got the swap finished, no problems, i think im gonna do it all over again and swap the sohc 1.8 16v, this cars to slow, haha, but i need a brake from the garage, and need to do some more research for the swap. thanks for the input from the board.
                    switching engines from automatic to manual
                    I did that already, swap the engine electrical harness over from the old engine to the new one it's easier than trying to splice wires, trannies have different connectors. Other than that you just have to take the torque converter and flywheel off the automatic and put on the manual flywheel (they are different for the transmission types) and you pressure plate. Line up the pressure plate w/the tool (some pressure plates come w/then ) and you'll be rock'n in no time.
