Driveaxle locknut size! Help!
  • Driveaxle locknut size! Help!
    Hey! I need to know what the driveaxle locknut size is. I'm doing the CV axle, and replacing the lower control arm in the morning, and I have no idea what size socket I need for the big lock nut. Please help quick!
    Http://www.Youtube.com/TheresGabe
    1991 Festiva L Red: Daily Driver
    1990 Festiva L White: R.I.P.
    1988 Festiva L Silver: R.I.P.
    1991 Festiva L Red B6T: R.I.P.
    1989 Festiva L White: R.I.P.
    1995 Aspire 2-door White: R.I.P.
    1995 Aspire 4-door Red: R.I.P.
    I am pretty sure it is a 29mm iirc. Let's see if anyone else has some input.
    93 Festiva L White B6T
    99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
    89 Festiva Blue
    91 Green “Mad Maxine” Festiva B6T
    93 Festiva GL Black BP automatic
    93 Festiva GL Green stock
      1 1/8 works 6 point
      works for me fits very snug (kobalt Impact socket)
        factory is 29mm, some aftermarket units come with 30mm nuts. a 6pt 30mm socket will remove either.
          I use a 1 and 1/8. Don't know what that is in mm.
            I have also had a lot of luck with 1 1/8"
            Walth
            Festiva #1: 91 Red L 4/5
              guys... these are asian cars... that means metric sizes. (not saying 1-1/8" isn't 30mm, it is, "but proper tools for the job" should be advocated here).
                I used a 30mm and it was a little loose, but did the job...
                  Strangely enough there are some 'standard' sockets that fit equally well on 'metric' bolts, especially for the larger ones. "Run what ya brung" is quite fitting (so to speak) when you're on a budget, and they don't strip the heads.
