Originally posted by gadelbert1
Then work it toward the fire wall, then back to the block, back and forth, till it's easy to move by hand.
Might take a while, patience will be rewarded with no more broken parts!
Uh, you have disconnected the speedo cable from the gear assembly, right?
Take the time to clean off the crud BEFORE you finally get it to move back and forth.
An old tooth brush works well in this confined area!
You have to understand that this assembly probably hasn't been opened in decades!
