Hey guys a few things. I can push the lifter down on my b6t aren't the supposed to be solid an two. Will these fit if I needed new ones
b6t lifter ???
b6t lifter ???
Frankie
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
Should have said something and I could have thrown in some lifters with the valves/springs
I know man but I didn't know I'm no mechanic lol I was just pushin on stuff an noticed that mine can squeeze some of them down too its ok I found new onesmi on ebay but nqot sure if they fit the for a 91- 93 miata 1.6Frankie
Keep in mind if the lifters have no oil in them, they probably will move, so they're probably fine
Well some make noise when I push them down an some don't I just wanna make sure I take care of any problems while its all apart ya know it sounds like suction when I push it downFrankie
could be partially filled with oil as well, but i understand where you coming from
rebuild them! its simple, get to cans of carb choke cleaner, pull the HLA out (remember which way the spring goes, blast the check ball, reassemble HLA, submerigine in oil, use a paper clip to push in the check ball while pumping them under oil til they get stiff. or send me some cash and ill rebuild them for you. Just number them before pulling them out of the head.
Hmm ill have to try that thanks manFrankie
Originally posted by Hot_Wheels View Post"FLTG4LIFE" @FINALLEVEL , "PBH"
"cleaned" would be a better way to put it. The B series HLA's are prone to loading up and clogging with crap due to the tiny orifice in them. Mazda revised them down the line with a larger orifice in the later BP's and KL's (I believe they used same or similar HLA's) Restricted flow to the HLA's internals causes the cams to slap the top - making a lifter "tick" common on the B6T
Either way, they come apart easily. Squeeze them under oil a couple times to fill them up before re-assembly. I've never numbered them when pulling/reinstalling them personally and I've not had an issue. They are intended to constantly rotate in the lifter bore to avoid wear on the top of the lifter.
If you see some with an hourglass figure worn into the top, they should be replaced.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
you stretch out the spring too which freshens them up a little bit, I did it to most of mine even if they didn't need it.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
