I've installed the 96-97 aspire motor in the festiva & looking in the hanes manual under Ignition timing it says
90-95 Set it on White Mark 10 BTDC
96-97 Set it on Yellow Mark 10 BTDC
I set Crank TDC on the white mark since that is what Haynes says to do on earlier model years but thats whats got me thinking. Should I keep this engine on the white mark or time it to the Yellow Mark since it is the newer engine?
