oh, ok so can i get that part at like auto choice, also, does anyone know the firing order of the rotor cap? i don't think my wires are even in the right spot lol, what should it be if your looking at the rotor in relation to the drain stud on the cap
intermittant stalling
1-3-4-2;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
'92 Festiva L M/T
'93 Festiva GL A/T
http://autorepair.about.com/library/...l-fo-11162.htm
this link is for carberated but it is the same firing order for all festivas.;
'92 Festiva L M/T
'93 Festiva GL A/T
Tell the nimrod (they usually are nimrods) behind the counter that you need to replace an inline capacitor. Have the numbers written down off the side of the capacitor and it'll probably match up with something they have.Originally posted by funky technician View Postawesome! one more question :-) if i wanted to replace that capacitor thing by the coil, what would i ask for at the parts counter?1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
OK, so the car is still doing the same thing, the ignition just cuts out intermittantly while driving, it seems certain throttle applications induce it more, then it will be fine for a bit, would this inline cap do this? i'm gonna change the coil when i get home, thats the only thing in the ignition system i didnt change yet
