Originally posted by Bert
Front Right rattle noise
I'm no ASE mechanic, but I think I've located the problem. photos on the way as soon as I can figure out these damn interwebs.
And to kingfish......and George B......I'm assuming you two are romeo pukes. I didn't make the link until just now that you two were talking about the same thing.
I was Armament. And I've got Duct Tape. Be afraid."I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
Left Side
Right Side
This is one of the long pole type things leading from the shifter.
I'm no genius, but I'm thinking there should be some sort of bigger bolt to hold that end on.
I'm also thinking of doing the fix for the "shifter falls through the floor" to tighten up that whole thing once my short shifter arrives. Any cons to that fix?"I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
Can I pick up those boots off a car at the yard? or is getting new ones from mcauto the only way to go?"I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
OK, I need someone to tell me what this piece is called.
This is the transmission end of the long rod from the shifter. It relays the forward/backward motion of the shifter. I'm missing the rubber piece that sits inside this. Without this rubber thing, I not only have a lot of slop in the shifter, but there's nothing REALLY securing it there. I can't even look for the part until I find out what to call it! Please let me know."I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
Rockauto.com has the steering rack boots, The rod that runs with the shifter, I believe is called the transmission stablizer. Not sure where you can get the bushing for it.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Shift Stabilizer Bar. The bolt is the right size, but if it is loose, the bushing inside is worn, rotted. I highly recommend you pick up a Haynes manual. Pretty good if you can turn a wrench and follow instructions, then you can decipher more of what car guys sayContact me for information about Festiva Madness!
Originally posted by Dare View PostI'm no ASE mechanic, but I think I've located the problem. photos on the way as soon as I can figure out these damn interwebs.
Originally posted by Dare View PostOK, I need someone to tell me what this piece is called.
For years, I just had a bunch of washers that barely fit inside, and two bigger ones on the outside. Worked kinda a'ight.
I doubt that is his noise, though. These usually make a clunky sound when you move the shifter.Contact me for information about Festiva Madness!
15R is the mos designation for maintenance/crewchief on apaches. Phoenetically R is Romeo. Thus all.crewchiefs are commonly called romeos. I was 15Y, or Yankee.
You mentioned helo parts. Parts Thx a Romeo would typically be very familiar with. Bankers, not so much.
No wires go to a swashplate and therefore not my thing."I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
I probably should have put the shifter thing in a separate thread. I found a generic "shock bushing" kit that will likely work. More to follow.
As far as the noise.....definitely cv boots. Mine are destroyed. Will I need to put the car on jacks to replace those arms? Or can I use a pair of ramps? Ramps are much easier and less scary. Finding even ground for repairs in my hood is challenging. I have a garage, but it is currently occupied."I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
The wheels haveto come off, so.....
Beamed to you from an insane asylum in orbit around Saturn via Tapatalk.Contact me for information about Festiva Madness!
Advanced Auto Parts has this. There's 4 bushings in the package. I took the pic after I installed them
I shaved about 1/8 inch from the outside of the bushings and they were perfect.
Problem solved. Problem staying solved."I hate war as only a soldier who has lived it can, only as one who has seen its brutality, its futility, its stupidity." -Dwight D. Eisenhower
