My 93 just developed a very very loud whine from the fuel pump in the tank , it only happens during acceleration and when the tank is more than 3/4 full . No other symptoms , runs great . Car has new fuel filter under hood and 5k on new motor . I used the search but couldnt find an answer . Thanks for any help ... Im guessing just change the pump but thought i would ask .
Fuel pump loud whine at acceleration
My walbro 255 wails like a banshee when the fuel gets hot, but is quiet whe the fuel is cold. It runs fine either way, and I've just gotten used to the noise, but it freaks my passengers out sometimes. The stock pump should be quiet all the time, but yours may have broken free of it's bracket and started to vibrate or something. It may not need a new pump, I'd take a look at the bracket and sending unit first. It's a puzzle getting it out, but be patient, you'll get it.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
After inspecting the bracket - sending unit all looks tight and in order > The noise is so bad , a bit like letting the air out of a balloon when you pull the end sideways , yet 10 times louder ! The noise is only under load and when tank is above 3/4 full . So nobody has experienced this ? My parts store wants 118 for a new one , guess i will go that route unless someone can offer further advice .
top of the sending unit, only if it dies-Greg
Redneck Engineer
FOTY - '09
Could it be a tiny leak on the hose or loose clamp(s)? Maybe you can bench test your pump, clean it as well. I've done it using lacquer thinner on a small container. You'll need a hose to revert the liquid back to the container. Hope this helps.Originally posted by avitsef View PostAfter inspecting the bracket - sending unit all looks tight and in order > The noise is so bad , a bit like letting the air out of a balloon when you pull the end sideways , yet 10 times louder ! The noise is only under load and when tank is above 3/4 full . So nobody has experienced this ? My parts store wants 118 for a new one , guess i will go that route unless someone can offer further advice .
Godspeed...
click here for FORD fESTiVA and KIA pride parts - JunSpeed Parts
our humble rides
1965 Ford Mustang Coupe 200ci C4 AT (my 1st car, parked on a far island for restoration)
93 LX B1 carb sedan (my first festy - SOLD
97 CD5 B3 carb (used to be my DD - SWAPPED)
94 LX MAZDA Z5 EFI (gettting roadworthy)
Z200GS 200cc bike (SOLD)
95 Lancer Mirage GLXi (wifee's ride - SOLD)
97 Lancer Mirage GL carbed 1.5 (Garaged)
Kymco K-Pipe 125cc (Garaged)
97 Proton Lancer carbed 1.5 (son's DD)
2015 Spacestar Mirage 1.2 CVT (my DD)
