My car has been showing low idle and complete low end no-power issues, especially when cold, for awhile, gradually getting worse. With lots of clutch slipping, and over revving, I can get it rolling, but it's embarrassing. So far I have replaced fuel filter, plugs, plug wires, cap, and rotor. Everything helped a little. I poured a dose of seafoam in the tank and filled it.
In poking around I managed to mess up the original vaf female plug, but I found out a vaf from a 1991 protege seems to swap over without complaint. I can't see how you see the timing marks unless you have eyes on sticks, but I changed the timing "just for fun". Turned the idle up with the idle adjustment screw. Wiggled the wires.
Un plugged the temperature sensor (on the injector side), threw a different code. Un hooked O2, threw no codes. Used the screwdriver stethoscope and the injectors are all clicking.
Drivability is a little better, but CEL comes on, (usually simultaneously with power loss), after about 5 mins on the freeway at 65. Stick in the clutch and rev it, light goes out. It is just about predictable enough to go ahead and try for Festiva Madness.
Any ideas?
Thanks.
Any ideas?
Thanks.
