Pulls! (Left with throttle, right when off)
  • Pulls! (Left with throttle, right when off)
    Ugh... I got the last issue fixed, and now it's time to face the next one:
    When I'm driving, when I have my foot in the throttle, the car pulls to the left. (Almost like it's rearing up. Feels like the rear right is dropping and the left front is going up) When I left off the gas, it pulls to the right. (Feels like it's dropping back down from the before described throttle) It's a little bit scary. I've replaced the LCA's, and I'm probably doing my outer tie rod ends tonight. (Hoping this might fix it?)
    Anybody have any ideas what might cause this?
    1990 Festiva L White: R.I.P.
    1988 Festiva L Silver: R.I.P.
    1989 Festiva L White: R.I.P.
    Check front suspension rubber bushings and especially the motor mounts.
      sway bar bushings. Check where the sway bar goes through the LCA and make sure they are tight.
        VERY good idea! Come to think of it, it started doing it AFTER I replace the right side LCA.
          Anything loose in your front end could cause this. Check the control arm to body mounting points. Make sure that is properly torqued and that the nut on the inside is not spinning.
          #33 Ford Festiva "We Are Not Really From Iran" - 24-Hours of LeMons 3x Trophy Winner & Class B Winner
            +1
              Originally posted by Larry Hampton View Post
              +1
              I think I did them "pretty tight" Can they be "too tight"? or should I just tighten them, til they can't be tightened any more.
                check sway bar @ LCA, ball joints and possible tire failure.
                1989 Carby L: Stock. Slow.
                1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
                2016 Focus ST: daily driven go-kart
                  It's not the nut, it's the bushings that are shot and compressed.
                    Should have loosened the sway bar bushings at the front when replacing the control arms. If not try loosening and retightening. If so check that they were retightened. As suggested also check for deterioration and deformation of the rubber.
                      Don't overlook the obvious check tire pressures
                      -M3NTAL MARK! Woo!!
                        Do you still have one short and one long cv shafts. Because if you do you might have torque steer. I have it on my car and I put on new lower control arms and new energy suspension sway bar bushings and my car is better but still shifts left and right depending on throttle.
                        93 Festiva L White B6T
                        99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
                        89 Festiva Blue
                        91 Green “Mad Maxine” Festiva B6T
                        93 Festiva GL Black BP automatic
                        93 Festiva GL Green stock
                          he has movement when he lets off and gives it the gas.....usually sway bar or lca movement.
                          You just have to much power on take off giving you torque steer....lol
                            Problem solved. When I replaced the LCA's, I used the old cotter pin on the passenger side. Well... I guess it came out. The not on the sway bar, was on the 2nd to last thread! Tightened up, NEW cotter pin, and checked the other side which was fine, but I put a new cotter pin in it just for good measure. MUCH better!
                              Thanks for the update.....knew it would be the bushing situation....good thing you asked and looked before it came all the way off.
