Back to your blow-by issue. Have someone run a compression test, on each cylinder. If you fine that one cylinder is way lower than the rest, then you probably have a big problem. I had an issue, with blow-by, where oil was collecting right after the VAF. It was so bad it actually kept blowing the dipstick out! Once I ran a compression test, I found that one piston had a broken ring, and was toast.
Good luck,
Scott
Good luck,
Scott
