Crankshaft Angle Sensor (CAS) or Crankshaft Positon Sensor (CPS)
  • Crankshaft Angle Sensor (CAS) or Crankshaft Positon Sensor (CPS)
    Hey guys,
    Not sure if the festiva calls it's crankshaft sensor a CPS or CAS.
    Does anyone know any technical details of how the unit on the festiva works? Connector pinouts?
    I'm building a digital tachometer and want to use the existing CPS signal.
    1993 Ford Festiva "Superleggera" 5-Speed
    McMaster Engineering Custom Vehicle Team
    The position sensor is in the distributor. Don't know how it works. There is an RPM test connector by the coil to hook a tach. I think it works by ign pulses.
