MPG dive
  • MPG dive
    So all the sudden I went from about 40-41 MPGs to 33. I have noticed it dropped a little but I haven't been driving it a whole lot. I haven't noticed any kind of puddle or smell from a gas leak. No running issues its running like a champ. I'll run 1 more tank and see what happens, any ideas if it doesn't come back up from anyone?
    1993 Festiva GL The Besty Festy
    1) Is your air filter in relatively good/clean condition?
    2) Check your vacuum lines for cracks or any suspicious problems... especially the FPR vacuum line.
    3) How is your ignition timing at the moment?
    4) Have you had a look at the O2 sensor as of yet?
    5) Tires still inflated to proper spec?
    6) Do you hear or feel any drag from your brakes or bearings at all? Does the car decelerate normally?
    Just a few ideas on light/easy projects to get started on.
    1988 Chevy Sprint Turbo 997cc
      maybe some bad gas?
      2006 Dodge Magnum SRT8 (Wifes)
      2002 Ford Excursion (Family Mobile)
      1988 Ford Festiva LX (Mine)
        Temperature drop=lower tire pressure. Along with "winter blend" gasoline.
        Just my 2¢.
          Yeah but all this stuff shouldn't make it take a dive like that. Last winter around this time it barely dropped off at all if any. O2 sensor is less than 2 years old it should be fine. Tires should be close I'll check them though. Temps haven't dove here that much yet. I'll check the filter I imagine its fine too. It was just real random it seems like. Like I said I am going to run this tank and see what happens and go from there.
            Update on this...I'm a dummy. I totally forgot my speedo drive unit had broke so I drove it a couple days with the speedo and tach not working. Therefore showing I traveled less miles on that tank and making my MPGs dive. :banghead:
              Yea, i suppose that could give worse results also......
                I wonder how much better you really got lite footing around!!
