Well i looked for vacuum leaks, checked the coolant temp solenoids, replaced the fuel pump, checked plugs, wires, dizzy cap, sprayed carb spray on vacuum lines and even tried adjusting the idle/air screw and it still wont idle on its own but i am however able to drive it. One thing i did notice is that it seems to be more responsive and its not bucking so something helped a little but as soon as i take my foot off the gas it dies. Could i possible have the idle/air screw adjusted wrong? Which way do you turn it to lean it out and visversa? Is it possibly time for me to do a carb swap????????
