Hay all,
any tips on how to secure the 3x bolts on the water pump pulley?
I did a time belt and water pump change but i don't think i did the water pump pulley bolts to tech torque specification, as when i wanted to tighten those bolts, it's almost impossible as the water pump pulley simply spins when you try and do them up.
Water pump pulley make a slight rattling sound as i havent got those bolts as tight to specification.
Any ideas ? The car is a 99 Festiva which is the same shape as the Aspire 97.
Cheers, Jase.
Cheers, Jase.
