how do i rebuild the carb on a 89 ford festiva lx ? and how do i get it off? i have removed the 4 main screws and all of the hoses but it still wont come off? its frustrating...
carburator diagram rebuild how to
I personally do not believe the stock feedback carb is worth rebuilding. Have you considered a Weber or Escort carb replacement? I recommend drddan's Weber replacement thread 30959.
To remove the stuck carb, simply get a chisel, position it exactly at the base of the carb flange and give it a gentle tap with a small hammer. Try to avoid cracking the heat sink below the carb. Good luck.Last edited by bravekozak; 11-11-2012, 05:42 PM.
Originally posted by bravekozak View PostI personally do not believe the stock feedback carb is worth rebuilding. Have you considered a Weber or Escort carb replacement? I recommend drddan's Weber replacement thread 30959.
Hi Bert. Thanks for the test drive in your Festiva. Don't forget to post a picture of your ride with the new hatch. Yes, I have a full set of machinists hammers from very small to regular size. I believe in always using the proper tool for the job. If I don't have it, I will buy it off of eBay for ten cents on the dollar. The carb gasket is just slightly crushed and baked on with engine heat. That's all.
I trust everyone is actively searching for imbedded links.
