ok i give , i put the air on the vents and its not heat its freezing cold and even when the heats on my feet or defrost the vents above the radio still have cold air coming in and yes my heat is hot .also i plugged the exterior vent hole under the cowl it didnt change this annoying cold air coming thru the center of my dash why wont the vents allow hot air confused anyone else have this issue ?
Sent from my PC36100 using Tapatalk 2
