as the normal headlamp capsules are 75$ + how to go about putting in the universal ones, is it to much trouble. my other friend is giving me 100 bucks to get things i need to get it going. so how much trouble are the universal headlamp capsules to get in?
universal headlamp capsules how to
I think he is just talking about a headlight? Try looking for a local junk yard, you could get one there for under $20 if you can find one in decent shape. Or put up a wtb thread here and someone could probably help you out. Much cheaper than $75 or trying to get a universal headlight to fit.-------------------------------------------------------------------------------------------
My Musica! Click me!
Originally posted by Charlie1717 View PostI think he is just talking about a headlight? Try looking for a local junk yard, you could get one there for under $20 if you can find one in decent shape. Or put up a wtb thread here and someone could probably help you out. Much cheaper than $75 or trying to get a universal headlight to fit.
I always just called 'em headlights. The bulb is a lamp.1963 Fairlane - future NSS drag car
98-2000 ranger headlight assemblies are almost a direct bolt in. Check Ebay. if you get them without the turn signal/side marker light the metal piece under the Festiva headlights can stay. Here is an example: http://www.ebay.com/itm/98000-RANGER...05d98d&vxp=mtrLast edited by Team Lightning; 11-20-2012, 12:23 PM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Re: universal headlamp capsules how to
Yes, although you'll have to modify the light mounting pass-through area to allow for the additional light (turn signal/projector) to pass through the housing, and you will have to trim your grille to the angle of the new lights.
Last edited by DriverOne; 11-20-2012, 12:45 PM.In love with a MadScientist!:thumbright:
Just the glass wont fit. To use the ranger assembly you need the complete units. Both sides. Also the ranger uses 9007 bulbs for those yrs. Festiva's uses the 9004.Jerry
Team Lightning
93 L Lightning. BP
That generation hasn't been tested yet. 98-00 is the only one we know works, but if you can find one in the junkyards, try and see if it will fit.In love with a MadScientist!:thumbright:
