Hey all,
So I've been developing a strange noise/phenomenon on my B6T swap lately that I'd like to decipher. When completely cold on first startup and second startup, she'll stall almost instantly after barely attempting to idle. After a short drive down my block, I'll put the clutch in and she'll die almost instantly. After that slightly-driven stall, it'll be almost impossible to start for several cranks. After those several cranks, she'll barely idle very low and eventually come to life. However, when she does come to life... it makes a strange blubbering noise that is similar to what noise you make when you blubber your lips with a finger in front. That brbrbrbrbbrbrbr noise. Sometimes, it'll go away when the car warms up... but often the blubbering sticks around, which drops my power and makes the car considerably harder to drive. Any ideas on what's going on here? Thanks everyone,
Aaron
PS - I have hood vents, which could be contributing as water occasionally gets into the spark plug holes. Working on a solution to that but this issue seems somewhat separate to it all.
Aaron
