So we went out of town for a couple days for Thanksgiving. Temps were up when we left had been driving the car no issues whatsoever. I put it in the garage before we left even. Temps dropped while we were gone and when I went to pull it out of the garage it didn't want to start. It finally did but then immediately died. I finally got it to start just enough to back it about 5 feet. It will just crank and not fire then every once in a while it will hit and then immediately die. Anybody have any ideas. I just changed the wires, cap and rotor about a month ago on it. Usually when its cold it will start then die but then start right up again. I need to get it figured out asap because we are down 1 car already after hitting a deer.
It just dies
Alright little update. Went out and messed with it some I got to thinking maybe the battery is just quitting it and it needs more CCAs. So I hooked my truck up to it and it fired right up was running smooth and I unhooked the truck then as I was unhooking the car it died. So I hooked it back up and it started then died. Did this again and I put it to the floor when it started to try and clean out an obstruction if it had one. It went wide open then died. Tried to start it back up but it wouldn't start. So I got the book out checked the coil connections all good there. Just not sure whats going on here.
It just dies
Might sound like an obvious question, did your belt go flying off?
I can toss a whole list of ideas out but you need to figure out what is missing when it dies.
Maybe pull the alternator and take it in and have it bench tested, if it passes then hook a fuel pressure tester in line, put a spark checker inline with a plug as well. Fire it up and when it dies see which is missing.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
I just went out and I have a good solid stream running into the fuel filter and the same stream running out of it. So that eliminates the pump and filter. I hooked it back up and it fired right up and ran as smooth as could be for about 15 seconds then it just dies like you shut the key off. I get no sputter or anything its just like you flat turned the key off. The alternator is new in the last 6 months and the battery still has charge so that shouldn't be doing it. New plug wires, rotor and dist cap as well. Which is what has me confused. If I was getting absolutely nothing that is one thing but the way it will start right up after its been left set is weird to me.Last edited by crusher773; 11-25-2012, 03:07 PM.
Ok so I also have good fuel at the rail. I pulled a wire at the dist and got no spark there. I pulled a plug and I got spark at the plug and a shock and it tried to start. I put the plug back in it started ran perfect for 15 seconds again then died. Pulled the plug back out and checked it again and I go no spark that go around. So I think its either the ignition module or coil because it is getting inconsistent spark it seems.
Yeah I wish I had an extra module or coil laying around. I am pretty sure I tossed a module that I though was a bad a while back. I haven't had to replace the coil though. I guess I'll buy both tomorrow and figure it out. Which one should I try first you think? That module is less than 2 years old.
A coil breaking down can cause the failure of the module as well.
Kind of a good idea to do both together, good thinking !
If you can get lifetime ..awesome! Keep the receipt in the car!Reflex paint by Langeman...Lifted...Tow Rig
Alright another update. I had pushed it kind of out of the driveway but needed it moved so I could get the other vehicles in and out. So I went to move it and it started right up. Moved it and it ran for about 30 seconds. Before it died the RPMs dropped and then came back up then dropped again and came back up and then it died. Anyone ever have symptoms like this. New coil is on still waiting for the module to come. I just want to get it going quick driving my truck is eating me up in fuel.
