Got enough spare fuel line? Attach it to the line at the fuel sender and run it to a low point. Siphoning takes so long, just jack the rear end up and throw a couple clean 5 gallon buckets under there!
Draining Gas
The aftermarket gas tank I put on my '89 Festiva DOES NOT have a drain plug. The original did. So your tank may or may not have a plug.
IF your tank has a plug, the piece that the plug screws into is probably soldered to the tank. Put too much force in removing plug and this may just tear away from the tank. In other words go easy when removing the plug.
I'm on Festiva #5 and have drained tanks and I've NEVER got more than the 8.3 gallons that the books says it should hold in it...Originally posted by sc72 View PostWell i must have missed something along the way, from our 90LX to our 93 GL, they are all ten gallon tanks.
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1989 Festiva L White: R.I.P.
Got a few gallons out today by jamming a hose into a plastic siphon pump. The other end was attached to the inline filter. A few squeezes and it will pull it out by itself. Except it stopped and I couldn't get it to work again. I think it was sucking air around the hose that was jammed into the tube. I might try sealing it with the finger of a latex glove or something similar tomorrow.
That's a lot of fussing around you're doing. I have 1 1/2 year old ordinary gas in the tank of my spare Festy and it still starts and runs fine. For peace of mind I do pour in some fuel stabilizer every now and again. I bought an LX parts car quite a few years ago and it had been sitting for at least 2 years. When I jumped the long dead battery it fired right up! My pickup truck has a carb and I don't like leaving it out for the winter with gas in the float bowl so I installed an in-line fuel shut off. Last run of the season I turn off the valve and wait for the engine to die on it's own. That ruse has served me well for the past 7 years.
Day three of smelling like gas: I figured out why the gas stopped flowing into the siphon pump. It wasn't because I lost my seal; It was because I lost my gravity. The top of the supply must be higher than the end of the drain hose. I put a scissors jack on each side of the rear and raised it 3-4 inches and was able to get about 6 more gallons out before running out of containers. This sounds like a lot of hassle but I want a controlled drain plus I don't want to disturb the tank drain that hasn't been touched in 20-something years.
If you honest to god have a gas tank drain (never been used though) I'd say "go right straight for it". Beats playing with loose containers, hoses and WallyWorld pumps and/or mouth suction activities.Originally posted by georgeb View PostDay three of smelling like gas: I figured out why the gas stopped flowing into the siphon pump. It wasn't because I lost my seal; It was because I lost my gravity. The top of the supply must be higher than the end of the drain hose. I put a scissors jack on each side of the rear and raised it 3-4 inches and was able to get about 6 more gallons out before running out of containers. This sounds like a lot of hassle but I want a controlled drain plus I don't want to disturb the tank drain that hasn't been touched in 20-something years.
A little misleading IMO. It's the C.A.F.E. --Corporate Average Fuel Economy. Meaning the average MPG of an automakers entire lineup. We will still have muscle cars, Corvettes, bigger sedans, pickup trucks, etc, but only because the addition of hybrids, electric cars, diesels and other fuel efficient cars effectively raises the average. Obama makes it sound like ALL cars will meet that MPG figure, which is untrue.Originally posted by Bert View Post....did you know that by 2025 (or thereabouts) average fuel economy of all vehicles in USA (and likely sub-servant Canada) is supposed to be the same as a Festy? A Hummer H1 with a 'mulch feature' Briggs & Stratton in it is all I can envision at the moment.
I can almost agree with all that...Originally posted by Bert View PostIf you honest to god have a gas tank drain (never been used though) I'd say "go right straight for it". Beats playing with loose containers, hoses and WallyWorld pumps and/or mouth suction activities.Reflex paint by Langeman...Lifted...Tow Rig
It goes in and out....Originally posted by Pu241 View PostI'd probably use the drain plug on the gas tank.
I understand that. Festys were marketed by Ford mostly to counteract their gas guzzlers of 20 years ago. But to get 'fleet average fuel economy' to equal that of a 1700 lb Festy is gonna take some serious work. The 'new equivalent' of Festys are therefore going to have to get 75 mpg. Maybe they'll be nuclear powered and the OEM gas tank will be filled once and then sealed to last the life of the car.Originally posted by deathegg View PostA little misleading IMO. It's the C.A.F.E. --Corporate Average Fuel Economy. Meaning the average MPG of an automakers entire lineup. We will still have muscle cars, Corvettes, bigger sedans, pickup trucks, etc, but only because the addition of hybrids, electric cars, diesels and other fuel efficient cars effectively raises the average. Obama makes it sound like ALL cars will meet that MPG figure, which is untrue.
Re: Draining Gas
There was an accident today, where a nu-power Fiesta was rear ended by a truck carrying fertilizer. A witness managed to get a picture of the damage.Originally posted by Bert View PostMaybe they'll be nuclear powered and the OEM gas tank will be filled once and then sealed to last the life of the car.
