insane engine problem!
This topic is closed.
  • insane engine problem!
    OK, this problem is on my dad's 90 FI. there is oil in the radiator. we replaced the head gasket and flushed it out and the oil keeps coming back. it is also loosing water. we replaced the radiator and several hoses that have busted. there is no visible steam coming out of the exhaust. it still runs perfectly, but it's starting to get annoying. and my dad is afraid the oil will start to deteriorate the rubber hoses and water pump seals ( this theory is strengthened by the busted hoses). we have no idea whats wrong, other than a cracked head/block. any other suggestions?
    89 L, hopefully returning from the dead soon with a little more power... :twisted:
    http://www.fordfestiva.com/forums/sh...77-my-89-build
    when you replaced the head gasket,
    did you have the head checked out by a machine shop too?
    and was the head milled?
      no, but we could not see any scratches, cracks or anything else.
        you can't see a warped head
        there was a reason you replaced the head gasket in the first place
        and head gaskets fail for a reason
        and only replacing them , will not make the problem go away
          got oil in my radiator too, but its because my engine has a hairline crack in it, really messes with the cooling of the engine.
            a warped head would have us doing the exact thing that we don't want to do: buy a new head. wouldn't it? anyway, my parents have spent plenty on it and aren't inclined to spend much more. parts for festys are ridiculous! :evil:
              There are several heads on here for sale cheap ,some used ,1 completely rebuilt
              Nonamekid has 1 used
              BROKEFESTIVA has 1 that has been completely gone thru ready to bolt on
              HD2500 Duramax Chevy
              Z28 LS1 power 500 +
                parts are rediculous if you go thru ford. if its not TOO bad of a warped head a machine shop could easily mill it down within specs for you. i had to have mine done not too long ago. i think they only charged me 20 bucks...its not expensive
                90 L FI..second B3
                90 L Parts car
                Jay
                  they may be able to do it cheap, but you still gotta pull the head off of it to get it done! and we're still not sure if it's the head or the block. it could be either one.
                    start with the easiest and cheapest first
                    then the block
                      The head is most likely the culprit. It is aluminum. You can't run a festiva hot!
                        Junkyard engines are very cheap. You can probably find a B3 or B6 for cheaper than it would cost to mill the head flat.
                        OX SMASH!!
                          Im so tired of new people bringing up threads that have been dead for a good few months.
                            yeah, that was a little weird. i just about forgot about it. (since its not my car!)
                              dude stop bringing back dead threads, this is what all your posts have been so far, why do i get the feeling ur just spamming forum to post in forsale section
                              2007 Ford Taurus 23-25MPG
                              1976 Chevy Silverado (my toy)
                              1951 Ford Deluxe, being rebuilt
                              Have an old car truck or tractor? Go here.
                              http://www.aintperfect.com/
