Crank pulley question
  • Crank pulley question
    I managed to chip off half a tooth on my crank pulley.
    Can I still use it or should I try and find a replacement?
    Thanks
    Sent from somewhere west of here!
    Ian
    Can you post a pic of the pulley? if you really don't wanna deal with it you should probably try to find a replacement!
    -1991 L 238k AC/Cruise Josh's future DD from neanderpaul, the clean slate!
    -1991 GL 171k AC/Rust free Jake's future DD (thanks kevin!)
    -1993 L B6T swapped auto(thanks rob!) 88k was 123whp 15.8 at 87mph currently undergoing surgery
    -1989 LX crazy project car you'll all see one day! (hopefully fm8 )
    Have one hydro g and xr2 mid shaft for sale super cheap! PM me!
    we have owned 10 of these cars to date and we're only 20 hahah.. call it an obsession!
      Re: Crank pulley question
      I'll post one up a bit later.
      Ian
        Which pulley you talking about? The timing belt one? If so I'd find a replacement since I'd hate to have premature timing belt wear from it
          I'd fix it or you'll always be half a tooth off bada bing.
            Photo as promised....
            I've already put a WTB in the appropriate section. Is the B3 pulley the same as the early B6 version?
            Ian
              Yup I'd definitely want to fix that for sure, but I'm not sure about if the B3's would be the same or not
                I believe it's the same as a B3, but you'll need one from an early B3 or B6, since it should have the small nose crank.
                I wouldn't run the broken one, BTW.
                  If all else fails you could probably build it up with with epoxy and shape it with a file. Drill a couple holes in the broken part and stick in some wire for bonding. What do they call that stuff that's epxoy and powdered metal?
