Wheel Bearing Diagram?
  • Wheel Bearing Diagram?
    I replaced my inner wheel bearing last night, and noticed that the thing that the bearings spin on was all pitted. I decided to continue with the new install. Once i was finished it drove around the block nice and quiet, so I went to bed. While coming home from school yesterday it's making the noise again, and possibly even louder. I'm thinking that the pitted thing the bearings spin on is the reason. However, I would also like to make sure that I put the spacers in correctly. Does anybody happen to have a diagram of the wheel bearing? I can't find one anywhere...
    Thanks!
    Front or rear?
      front
        The bearings and races are matched sets, I've mixed and matched before without problems, but they are supposed to be replaced at the same time, pitts and rust are definitely not good.
        The hub shaft being pitted shouldn't be an issue, as long as its round and not oval, and the bearing can slide on and off unhindered.
        2008 Kia Rio- new beater
        1993 Festiva- Fiona, DD
        1997 Aspire- Babyspire, DD
        1994 Aspire - Project Kiazord
        1994 Aspire- Crustyspire, RIP
          Yes , pitting on the shaft = who cares. Although if there pitting IN the cup where the cylindrical rollers goes against , you have a problem. The inner surface of the cup must be pristine , and grease plentiful.
            The front bearings spin on the bearing race of the cups which you should have replaced when you replaced the cone (bearing cage).
            Here are some photos: http://www.photobucket.com/Festiva-frontwheel
              Hate to be 'That guy', but are you sure you should be attempting to replace hub bearings if you can't ID a bearing race? I would rather rebuild a head than do another set of hubs. If you got it done, disregard my comment and good for you.
              Going old school...
                Just because we don't know the technical term doesn't mean we are not capable of replacing it! ohsnap
                Thanks to all with the help. I think it's the race that is pitted. The shaft is fine.
                  Sorry man. No offence intended.
                  Going old school...
                    Hope this helps.
                    its a bit universal but the same idea applies
                      None taken lol, I understand your viewpoint.
                        Originally posted by yousufwalton View Post
                        Hope this helps.
                        [ATTACH=CONFIG]10991[/ATTACH] [ATTACH=CONFIG]10991[/ATTACH][ATTACH=CONFIG]10992[/ATTACH]
                        I think this is what we need. Thanks!!
                          =P remember click the rep button lawls
