Does anyone know how far from the top of the block the top of the piston is at top dead center? I went to the junkyard yesterday to pull a cylinder head and tried to turn the motor over manually so I could get a measurement but I wasn't able to rotate the crank.
If someone has a motor out of the car w/the head off could you try to turn the motor over and get a measurement for me? It doesn't have to be EXTREMELY accurate, if you use a ruler and can get with in either 1mm or 1/16 inch that would be fine.
Thanks
Thanks
