My recently retagged but old '93's charging light came on last night. Made it home. Voltage does not increase with RPMs. Anything else to check while it's on the car? Also I have a spare serpentine belt alt. Do the pulleys interchange? Which direction are the threads?
Charge Light
Take alternator off car and take it to Autozone and they will put it on a bench and check it. If alt not working right, I would not drive car up there if its not charging battery.Last edited by milehighbear; 01-05-2013, 07:00 PM.
Id make sure to pb blast and wire brush the battery terminals and wire ends really good before I go to too much trouble. My buddys s10 had been giving him problems, he swapped alternators and the light kept comming on. The battery is almost 10 years old and he was going to change it until I cleaned the terminals, they didn't look dirty or corroded at all, but its been working fine for almost a year now.
I don't know where you got that 4 rib belt pulley but I've put an aspire pulley on a bg chassis (70 amp) alternator without an issue.Last edited by zoom zoom; 01-05-2013, 07:11 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
