Any one up that i can call or can call me got everything hooked up and now I don't think my fuel injectors are opening could really use someone to as could really use someone to ask questions
festiva 911
I'm at work I'll help inbetween jobs. Why do you think its injectors?
FIRST MOVE YOUR QUESTION TO REPAIR HELP FORUM PLEASE.........Last edited by nitrofarm; 01-06-2013, 02:46 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Injectors receive power from fuel pump relay,ECM completes they're ground. So you say you have fuel at rail so that means injectors are getting power as well.Also you have spark so that rules out a broken Timing belt or failed CSP sensor.So maybe you did swap fuel lines? Or the ECM isnt completing the injector grounds. Double check fuel lines,then swap in another ECM if still no run. Thats all I got. Next time you need to put a 911 in the REPAIR HELP forum ok. Good luck, keep us posted I'm sure the mod will move the thread for you.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
