My 92 Festiva check engine light is on and i went to scan it and cannot find the port for the scan tool to plug in. Any help would be greatly appreciated.
Festiva diagnostic port location
Read many many threads, my son!
You have much to learn!
Festivas are a pre OBDI design.
No socket.
See georgeb's post.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Get the code after doing as georgeb suggested post it up here.
Depending on the code and when the CEL lights-up we can more accurately tell you what needs to be repaired/replaced.'93 Blue 5spd 230K(down for clutch and overall maintanence)
the cel doesnt come on when i start the car just when driving. the car starts surging going down the road like its a weak fuel pump but pump and filter are new and i made an inline pressure port to check pressure with fuel gauge. 30 psi which is i believe is properLast edited by red rocket 2; 01-10-2013, 11:23 AM.
Under the hood next to the booster and coil. White or Clear, it is the same plug.Originally posted by red rocket 2 View Postare we talkin under the hood by the booster or under the dash
Try finding a good ground, don't fully start the car, just turn the key to the "On" position. The CEL should blink if it has a stored code, long flashes indicate first digit, and the rapid flashes indicate the second digit, if there are no long flashes, then the first digit is 0.
For example, one long flash, and four rapid ones, indicate a fault code of 14.
I know my coolant sensor was sporadically faulty, only flashing the CEL occasionally when driving, but it stored the code for me to check it.
Tell us the digits, one of us should be able to tell you the fault code's meaning. Most of us have the Haynes Manual which lists the fault codes.Last edited by TorqueEffect; 01-10-2013, 12:14 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
