Hi sorry if this isn't the right place but I'm looking for a mechanic in Minnesota close to St Paul for my Festiva in need of some engine work came home and engine is covered in oil. I just had brought it back from my cousin who is more of a parts swapped than an actual mechanic no disrespect to him, but I think this is just beyond his abilities since this is the third time he has tried to fix my oil leak. Any way I figured I'd check here before craigslist thanks.
Looking for mechanic in Minnesota
Hopefully there is someone near by that can help! For now it would probably help if you took a pic of the said oil in the engine bay to give us a better idea of the situation. Can you see where it is leaking at? Valve cover? Rear main seal? Oil pan?Originally posted by ramos1841 View PostHi sorry if this isn't the right place but I'm looking for a mechanic in Minnesota close to St Paul for my Festiva in need of some engine work came home and engine is covered in oil. I just had brought it back from my cousin who is more of a parts swapped than an actual mechanic no disrespect to him, but I think this is just beyond his abilities since this is the third time he has tried to fix my oil leak. Any way I figured I'd check here before craigslist thanks.-------------------------------------------------------------------------------------------
My Musica! Click me!
100_0907.jpg100_0909.jpg as you can see the tube from the crankcase to the intake was off there was a screw in the intake part and i think there must have been some think in the tube from the crankcase.I have removed the screw and put it back together the way it should but before i did, i ran the car and even at idle it seamed to have a lot of pressure coming out. Also my cousin did try to re-ring the motor for me at this point is all i can do to help this is add a catch can and would one with a breather be better ?Last edited by ramos1841; 01-13-2013, 01:36 AM.
