Freebird needs help! She's suddenly idling really rough (sometimes not at all) before dying after the engine is turned. If I pump the gas, or keep my foot down on the gas with my right and break with my left, the engine won't die. She's not getting much speed when I accelerate, and either my alternator belt is on too tight or the RPMs are really high when I accelerate; it's making an awful high pitched whirring sound. I'm afraid to push the car past second gear into third.. I'm not sure if these two issues are separate or have something to do with each other.. My thought is that it's the O2 sensor, but it could also be a split or loose vacuum line... Any suggestions on troubleshooting the issue? Thanks in advance!
Rough idle & dies, poor acceleration
year? if it's an EFI car, first thing to look at is the tube between the filter and the throtle body, if theres a crack or hole, fix it. next would be look at the ignition system (all of it). then move on to the fuel system (filter, pick-up sock, line pressure).Trees aren't kind to me...
Re: Rough idle & dies, poor acceleration
My thoughts: This happened almost directly after she fuelled up the last time. Is it possible bad fuel could play a part in this?
The car is an '89 auto.Last edited by DriverOne; 01-16-2013, 07:36 AM.In love with a MadScientist!:thumbright:
bad fuel be a culprit? absolutely.Trees aren't kind to me...
