I was wondering if i was able to put a 5 speed tranny out of a 92 festiva into a 88 festiva with a 4 speed? do i have to change axle shafts, or wound it even be worth it because i have read alot about people tring to rebuild the 5 speed, but not so much at all about the 4 speed. The 5 speed tranny has like 250,000 on it and i am doing a motor swap this weekend. Can i do it??
4 speed tranny to 5?
4 to a 5 spd
5 to a 4 spd
Direct bolt in same tranny ,5 spd just has 1 more gear
What swap are you going to do ?------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
How much does it drop the rpm's at 65mph?88L 328,000 winter daily driver
93L 167,000 summer daily driver (AC)
90LX 374,000 swap candidate
88LX black- parts
89LX burgundy-parts
91L red-parts
Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)
I think mine drops 500 rpm's more when I am in 5th vs 4th------------------------------------------------
Z28 LS1 power 500 +
Is that comparing a 4 speed versus a 5 speed?88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
No ,that is in my 5 spd.
That is the difference from 4th to 5 th gear about 500 rpm's
I believe 1 thru 4 in a 4 spd
is the same in a 5 spd 1 thru 4 ,then drops another 500 in 5th .
There is a thread on tranny ratios in here .------------------------------------------------
Z28 LS1 power 500 +
