4 speed tranny to 5?
  • 4 speed tranny to 5?
    I was wondering if i was able to put a 5 speed tranny out of a 92 festiva into a 88 festiva with a 4 speed? do i have to change axle shafts, or wound it even be worth it because i have read alot about people tring to rebuild the 5 speed, but not so much at all about the 4 speed. The 5 speed tranny has like 250,000 on it and i am doing a motor swap this weekend. Can i do it??
    4 to a 5 spd
    5 to a 4 spd
    Direct bolt in same tranny ,5 spd just has 1 more gear
    What swap are you going to do ?
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      Yeah, I went 4 ---> 5 spd. No problems, just a simple drop and swap.
      ...on your death bed, you will retain complete consciousness.....So i got that goin for me...which is nice...
      1993 Fester (gettin cruised like WHAT!)
      2006 HD Dyna SuperGlide (thumpin)
      88 Notch Stang (gettin built)
        How much does it drop the rpm's at 65mph?
        88L 328,000 winter daily driver
        93L 167,000 summer daily driver (AC)
        90LX 374,000 swap candidate
        88LX black- parts
        89LX burgundy-parts
        91L red-parts
        Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)
          I think mine drops 500 rpm's more when I am in 5th vs 4th
          Z28 LS1 power 500 +
            Is that comparing a 4 speed versus a 5 speed?
            88LX black- parts
            89LX burgundy-parts
            91L red-parts
              No ,that is in my 5 spd.
              That is the difference from 4th to 5 th gear about 500 rpm's
              I believe 1 thru 4 in a 4 spd
              is the same in a 5 spd 1 thru 4 ,then drops another 500 in 5th .
              There is a thread on tranny ratios in here .
              Z28 LS1 power 500 +
