So now that my port and polish is almost finished on this spare turbo manifold for my B6T, it's time to get the studs repaired and sandblast her before it gets all wrapped up and insulated and popped on the car. As you can see, I'm going to need some help with stud repairs. Two of the studs have broken off and I was able to extract one successfully so far. That final top right hole is going to take some more drilling and then a careful re-tap for sure. I know the threads on that open hole are M8x1.25 because a tap spun in without too much effort. However, the M9x1.25 die spins freely on the two studs I have there. Anybody have any leads at NAPA or Fastenal or anywhere else on where I can grab some new studs? I may just replace all four to be honest, but to have two more would really help bolt on a turbo! Thanks all.
Turbo Manifold Stud Repair
What I did Aaron was find a stud that threaded into the manifold and bought 4 brand new studs then bought 4 nuts that fit the other side, really didnt matter what size they were going to be because they were all new.
Worst case just drill and tap it, or if you want to put your purse down you'll go with a t25 turboLast edited by M3NTAL; 02-01-2013, 02:17 PM.
Originally posted by M3NTAL View PostWhat I did Aaron was find a stud that threaded into the manifold and bought 4 brand new studs then bought 4 nuts that fit the other side, really didnt matter what size they were going to be because they were all new.
So then I did a final double-tap on both of the open holes and they're flawless M8x1.25 now. Nothing is more satisfying than a successful tapping!
I guess my only task now is to get those two other studs out before I go shop for four new ones. What do you guys recommend... a little heat, penetrating fluid, and a big pipe wrench?1988 Chevy Sprint Turbo 997cc
Success at NAPA. The guys at the desk weren't sure what to give me, so I had a look around the store and found this assembly. PN#605-1347 is a water pump stud kit that comes with Grade 8 studs, lock washers, and nuts. Presumably it's for some type of old V8 or domestic or something... who knows and who cares. They're M8x1.25 and a perfect fit into my open holes.
Now it's just a matter of getting a garage to remove those old studs and getting everything sandblasted before putting it all together! Unless there's a way I could remove the studs myself. I don't have acetylene torches or high heat equipment though unfortunately! Those old studs wouldn't come out with the double nut method and penetrating oil and a pipe wrench seems futile and barbaric. The threads seem oddball and damaged as my M9x1.25 die is a bit loose and the M8x1.25 die doesn't fit on it at all. Best get em out and have all four shiny and matching to hold onto the turbo better!Last edited by Aaronbrook37; 02-02-2013, 02:10 PM.1988 Chevy Sprint Turbo 997cc
Re: Turbo Manifold Stud Repair
Crappy Tire has a stud removal tool. Just saw one there the other day.
Sent from somewhere west of here via Tapatalk!Ian
Originally posted by georgeb View PostShoulda welded a nut to it. If it breaks off flush, weld a washer then a nut to it.1988 Chevy Sprint Turbo 997cc
