Today I got into working on the Festiva.
The first thing I did was removed the timing belt cover and it was all tore up from rubbing. I think I heard of people saying that it happens a lot with them, what's up with that - why? Do people ever just leave them off? After that, I found out that my a/c compressor belt was totally gone.
Then I commenced to removing that air filter box, the top side of the filter looked pretty clean and I was really surprised when I removed it to see that the whole box was totally full of pecan nuts! Then I removed the water pump pulley. Well, after all of that I could see things a little better but I still have no idea where the leak may be coming from. The oil was all over the top of the left side of the engine and also dripping down from the bottom in many different areas.
Another member here suggested that I change the crank and cam seals. Is that a huge job?
The other day I was trying to figure out what my problem was and I found that the oil filter was totally loose! So I tightened it and thought that that was the problem. I took it for a ride and after around 40 miles or so it lost most of its oil.
Just to let ya'll know, I've looked closely around the valve cover gasket and really can't see any sign of leakage. The only place I can't see around the valve cover is directly behind the timing belt and I'm wondering if oil could be spurting out from there.
Oh well, back into it tomorrow. You think its worth removing my oil pan and checking and/or changing that gasket? Thanks.
