OK so on my 1990 5 spd i drove it almost 1 block then the car died after awhile a found out that there was no spark then when i got new spark plugs and there was still no spark i pulled off the distributor cap and looked at the points were the currant goes and that looked good then i decided to see if the rotor turns and it does not so i looked at the timing belt to make sure that that was not broken and when i saw that it was in OK condition i was not sure what the problem was and my friend told me that all the other belts spin when i try to start the engine. so would it be that the distributor is shot or would it be something different?
distributer
Take off the valve cover and see if the valves are going up and down when the engine is turned over? Bit odd to see some moving and some not.
ya today i finally worked on my car and i found out that the bolt that hods on the timing blet pulley Brock off so that that is why the timing belt would spin but the cam would not it was mostly because of my stupidity of trying to take my festive mudding and got it stuck in the mud puddle that was deeper than i thought it was and ended up getting water in my engine that made the cam start to seize up on me
ops:
Start looking for another engine.
so what you are really trying to tell us,Originally posted by McFatamya today i finally worked on my car and i found out that the bolt that hods on the timing belt pulley Brock off so that that is why the timing belt would spin but the cam would not it was mostly because of my stupidity of trying to take my festive mudding and got it stuck in the mud puddle that was deeper than i thought it was and ended up getting water in my engine that made the cam start to seize up on me
ops:
you accidentally missed some prudent information that would of ended this post a long time ago?????????? :roll: :? :shock:
