I have a 88 festiva LX i bought. I rebuilt carb, replaced plugs and wires, ignition coil, distrib. cap & rotor, fuel filter, fule pump, checked all vaccum lines, tried fuel cap removal trick. It is a pain to start. I live in south texas so it hasnt been to cold out. When i got to start it in the morning it takes 2-3 minutes to get it started. I have to sit there giving it gas for 5 min to get it semi warm just to get out the drive way. Once going everytime i have to stop it dies or trys to die. (WILL NOT IDLE). Once the car is warmed up it it will idel and run decent (still sputter and seems that it is lacking power). What should i do now?
Was thinking of doing a carb conversion... If so what carb should i use and what all do i need.
Any and all help would be greatly appreciated
