I'm about to put a "new" transmission in my car and wondering what oil to put in it? Also doing another oil change while I'm at it.
O'Reilly's guy said to use Mercon ATF fluid, but I found it odd to buy ATF for a MTF? I've looked around on here some and saw others saying they used that and others saying they used different stuff. I'm wanting to make sure I get the right stuff. The transmission I just picked up had 140k miles on it...if it was the original to the car I removed it from. Most of the oil probably drained when we removed it, but I'll drain whatever else I can and fill with what I decide is best. Right now this is what I was planning on putting in the car, but I saved my receipts so I can always get something else. I chose some High Mileage engine oil too cause my car is pushing 220k+!!
Any other suggestions for my tranny swap and general maintenance? I picked up: Valve Cover gasket, rear main seal, axle seals, shifter bushings, and air filter. Might do a flush on the radiator while I'm at it.
