Window Repair
  • Window Repair
    Has anyone taken their door panels apart to fix windows that are tilting when you roll them up? When I roll my windows up or down they are always tilting to one side and I have to push up on the window to get it to go up.
    someone on here had a write up, i think they showed hot to replace the felt guide? it may have been sc72?
      Thanks Hot Wheels and how is your project going. I did several things to rectify the window tilting but not much with the felt other than to straighten the felt and reglue it in the channel, while i was messing with the felt i cleaned the felt with soap and water, i did spray the felt with Armorall to help the glass slide.
      I once ask for help on here how to stop the windows from tilting and i got a responce from a smart young man from Joplin Mo. He said buy new Regulators so i jumped on e-bay and bought two new ones and yup they sure work good but those were the last ones to be had and i had more Festys to fix.
      So this is what i did as a repair, now assume you are looking at the window half way rolled up and the door card off, now you can see the two bolts holding the glass in place. i removed the two bolts and the plastic clips, now you can see the size of the holes in the glass, i measured the holes, bought some new nuts and bolts, drilled the plastic clips the same size as the whole in the glass, reinstalled the clips, nuts and bolts and tightened them that worked ok, the bolts have not come lose. Another way to tighten the glass was i grabed some steel tubing from work put that through the plastic clip and glass, also bought a shoulder bolt and nut, slid the bolt through the tubing then through the plastic clip and glass, tightened the nut, this also worked well and the glass has not come loose, The true problem is the plastic slide that raises the window up and down, this plastic piece rides up and down on a steel frame and as you know the plastic will wear out first, the repair i made was to keep the glass from coming loose on the plastic slide it's self, what i did was a good help but not a complete fix. Oh and by the way i did clean off the old grease on the slide mechanism and did regrease it, this alone helped the window roll up and down much easier. good luck and let us know if you come up with a new or better way to repair these parts.
        These parts were a big help to me in fixing the window tilt:
          [ATTACH=CONFIG]11545[/ATTACH]
          How many of these grommets should I order to fix one door window? Thanks
            Re: Window Repair
            So glad you all are talking about this. I needed to figure this out.
            HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
            "CL4P-TP" - 93 Festiva L
              Window Repair
              I should look into this as well since I have an aftermarket power window setup to install (it adapts onto the stock window crank, pretty neat setup lol)
                I'ts been a while since I repaired mine, but I believe there were two on each side. They snap into holes at the bottom of the window.
                Not sure if there was any change in this design between 88 and 93 though. Was a 90 that I repaired.
                I had three Festiva's when I ordered these several years ago so I ordered 6 of these at the time (used only 3 since then).
                  I bought new window channel molding from Four Green , and WOW!!!! at the difference it made in rolling up and down! Tightened the bolts and all screws in the door, and have been trouble free since.
                  After 6 years and 13 Festivas later, I have a Festiva that has no "wind" Noise while driving with the windows up!
                  93L sold. First FESTY!
                  93GL Sold Too Soon!
                    Re: Window Repair
                    Do you happen to have a part number still? I have yet to order from four green. I don't feel comfortable with their parts lookup.
                      someone else did the looking up/work, i saved it in a word file
                      here it is.
                      i still looking for a new belt molding equivalent
                      -chad
                      festiva weatherstrip from four green in korea
                      1. 3-door Kia Pride part numbers
                      MD00172761F WEATHERSTRIP QUARTER WINDOW, RH $15.62
                      MD00173761F WEATHERSTRIP QUARTER WINDOW, LH $15.62
                      MD00162761 WEATHERSTRIP - BACK DOOR $16.29
                      MD00158760B WEATHERSTRIP ASSEMBLY-DOOR, RH $18.29
                      MD00159760B WEATHERSTRIP ASSEMBLY-DOOR, LH $16.86
                      KKY0158605 CHANNEL-GLASS RUN, RH $10.29
                      KKY0159605 CHANNEL-GLASS RUN, LH $10.29
                      Here are the belt moldings part numbers and prices from Green Sales Company in usa:
                      Inside L/H E8BZ-6121457-A.: $25.00
                      Inside R/H E8BZ-6121456-A: $25.00
                      Outside L/H E8BZ-6121452-A.: $35.00 (out of stock)
                      Outside R/H E8BZ-6121453-A: $35.00
                        Those are what I got.
                        93GL Sold Too Soon!
                          Ordering the grommets today!
                          Will get the channel when it is warmer out!
                            if you're in a hurry and the grommets are not handy, i've done this with great results: remove old gromets from glass, take a strip of electrical tape wide enough to sit in the groove of the gromet that sits in the hole in the glass and apply 2 or 3 layers to the groove (i find that 2 is usually sufficient). then re-install the grommet. the layers of E-tape will shim up the glass and keep it from moving around as before.
                              WOW! $30 to ship a $11.00 part? OUCH! I might wait until I have a larger order.
