How much would it take to have a/c in my car it came with no a/c. Is it even worth it? And what donor cars can I take the parts from? Thanks
A/C conversion ?
I did it. I believe it was worth it. It was a pain in my case to route the A/C lines around my power steering lines. You can just take the complete A/C sytem and wiring from any A/C Festiva at the junkyard, and just transplant it. Make sure you use the exact size crowfoot wrenches on the fittings + lots of Mazola oil (penetrating fluid). I ruined one compressor by snapping the aluminum threaded connector off. You need a baby hammer to break up any seized fittings before turning. You really should relace every O-ring seal on every connector. They are cheap and I bought them in a box at Ford parts. You must be very patient when taking apart pieces that have been screwed together for over 20 years. Southern systems are preferable.
Here is a picture of what the air conditioner looks like installed in the dash.
You will have to do a search for the engine compartment picture.Last edited by bravekozak; 02-23-2013, 09:52 AM.
I have all the parts needed for a AC conversion on a NON-POWER STEERING car, pm me if intrested.Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
I finally found the picture of a non-P/S A/C system.Last edited by bravekozak; 02-28-2013, 09:02 PM.
