Originally posted by BigElCat
No spark after snow storm
Ok.. did check and it's clicking. I wacked it with the ratchet . just to make me feel a little better at least. Doesn't mean it's good. I think I got the Focus fixed so the Festiva may just set for a while. My parts car is down at the farm and with another snow storm coming may be the middle of March before I get down there.91 rusty Festiva 260k
eric, check your ICM!!!! power to the coil (black/white wire) is ignition switch controled. the yellow/green wire is the coil ground control and it can be checked with a test light. my first recomendation is for you to get to the nearest junk yard and nab a pair of ICMs from early 90s mazda cars. then swap one in and test for spark.Trees aren't kind to me...
Ok I'm stumped but still have to replace the coil, maybe the VAF and maybe the gas filter. It will run advanced all the way, almost but not quite there. The timing belt is still aligned correctly, replaced the distributor same symptoms. How could it go from running perfectly to over night to this? Guess there's always the possibility of a corroded wiring harness but haven't seen any corrosion anywhere. Bah why can't I ever have a easy fix!91 rusty Festiva 260k
I've replaced the dist., cap, entire coil assembly, and vaf. I've pulled the connections around the battery and all are dry. Thinking of the fuel filter but that doesn't line up with any of the symptoms. Tried grounding the timing wire by the brake booster and it flat out die's. Ran fine when parked and some snow and hasn't ran right since. End of May insurance is up and it joins the Aspire and parts Festiva on the farm.91 rusty Festiva 260k
time for a compression test!! and i suspect you're still off a tooth if the timing is that off.Trees aren't kind to me...
