Fusible Link….Help
  • Fusible Link….Help
    I need to replace the fusible link box that is mounted on the firewall, mine is burnt and causing a bad connection I do believe. I went and cut one out of my parts car but they are different, the one in the car reads "brown black brown" the one I pulled from the parts car reads "brown red brown" are they different and can I swap them?
    Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
    Nitrofarm has a good write up for upgrading the fusable link unit. There is a link that you can click on in his sign that will take you to it
    -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
    -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
      Thanks for the help
