Does anyone know if the speedo gear in a 4 speed manual will work in a 5 speed? Just for clarification I am referring to the one in the transmission, not the one connected to the cable. Thanks, Robert
Speedo gear swap question??
1988 Festiva w/ Rear seat removed and hatch area turned into dog cage, window tint, 1100w audio system, stock Carbed B3
Other addictions: 84 GT Turbo Stang (drifting car), 08 VW Special Edition HD Passat (1 of less than 12 in the US), 2013 VW Golf R, 2001 Silverado 1500 (Slammed)
Former addictions:03 Cobra, 04 GT Stang (wife's car)Tags: None
I have been assured for quite some time that the tranny speedo gear of an ATX, 4 or 5 speed Festy, plus that of a MTX Aspire, are one and the same. ATX Aspire is not, and I can confirm that. I personally did a Festy ATX to MTX speedo gear swap a few years ago without any problem.
Bert,Originally posted by Bert View PostI have been assured for quite some time that the tranny speedo gear of an ATX, 4 or 5 speed Festy, plus that of a MTX Aspire, are one and the same. ATX Aspire is not, and I can confirm that. I personally did a Festy ATX to MTX speedo gear swap a few years ago without any problem.
Your refering to the one attached to the differential not the speedo cable, correct.1988 Festiva w/ Rear seat removed and hatch area turned into dog cage, window tint, 1100w audio system, stock Carbed B3
Correct: this would be the gizmo with the nylon gear wheel that fits into the tranny. Just so you know the ATX Aspire item is about 3/8 longer than all the others.Originally posted by FestiHauler View PostBert,
