Hi I am working on an 88 and there is no spark from the coil I have replaced coil, wires and distributor car still no spark. Any suggestions ? Possibly ignition module ? Any help would be great I wanna get it running again it's getting fuel just won't fire. Just let me know what u think thanks
No spark
Same thing happened to mine a couple of weeks ago, same signs . it was a faulty ICM or pickup coil. I replace the whole dist. With module and all and it started right up I purchased the dist from rockauto and it was around $120 or so, I figured I change out the whole dist and play it safe. If you look at my thread on it you can see all the stuff I tried before we pin pointed out.
Hope that helps you ,
If you suspect the ICM (ignition control module, ie transistorized points) it can be taken out and tested for free at some auto parts stores, the ones who test batteries and alternators for free. When I bought a replacment ICM in Canada a few years ago it cost more than the distributor Dom bought. ^^^^Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by WmWatt View PostIf you suspect the ICM (ignition control module, ie transistorized points) it can be taken out and tested for free at some auto parts stores, the ones who test batteries and alternators for free. When I bought a replacment ICM in Canada a few years ago it cost more than the distributor Dom bought. ^^^^Last edited by Dom; 03-05-2013, 11:21 AM.
