Aspire head
  • Aspire head
    I am currently repairing a head gasket on my 89 festy. The local junkyard recently added an aspire. I was wondering if it will fit on my festiva and if so would it be an improvement?
    '89 L Charcoal
    '89 L Red
    '91 Ranger
    '65 F100
    Sepmer Fi
    Yes it fits, and it improves your valve train
      You won't gain anything from the Aspire head itself. It's the same as the Festiva. If your Festy head is in good shape, there would be no reason to spend the money on another head of unknown condition. The advantage of the Aspire is the roller cam and rockers. You could just pull those and install them in your Festy head.
      Isnt your 89 a carb'd car? If so, you would also need to convert to an electric fuel pump with a regulator, since I don't think the Aspire cam has a lobe to drive the fuel pump. If you already have the mechanical adjustable rockers, I would just keep it original. Switching to HLAs will just give you one more thing to give problems......just my opinion.
        Won't be any improved flow, but if you have a couple festivas you might want the head just as a backup if its cheap enough. As long as your festys are FI, carbs use a different cam.
        2008 Kia Rio- new beater
        1993 Festiva- Fiona, DD
        1997 Aspire- Babyspire, DD
        1994 Aspire - Project Kiazord
        1994 Aspire- Crustyspire, RIP
          My 89 is fuel injected. Thanks guys I appreciate the input I'll go rip the valve train.
          '89 L Charcoal
          '89 L Red
          '91 Ranger
          '65 F100
          Sepmer Fi
            Boy, you got sound, very fast, and very knowledgeable advice and in record time!
              That's why I joined the forum. Everyone I know gives me a dumb look when I talk about festivas and how awesome they are. I found my happy place here with you guys.
              '89 L Charcoal
              '89 L Red
              '91 Ranger
              '65 F100
              Sepmer Fi
                do yourself a favor: lap your valves in the head you get, then clean the heck out of it.
                if you want a little more flow without actually doing anything dramatic: remove the valve guide protrusions... Mr. Dickmeyer says its good for several CFM, and i did it to Skippy with noticeable results. if you would like more info about how i did it, i can hunt down the thread posted about it and what tools i used.
                  Please do, I would love to give it a shot
                  '89 L Charcoal
                  '89 L Red
                  '91 Ranger
                  '65 F100
                  Sepmer Fi
                    i used a 3/8" ball burr bit so it would self center and then blended the base.... takes about 5-10 min per guide to get the guide down and smoothed out. all by hand with a die grinder and some patience.
                    you can see in the first pic how thick the guide is and can visualize how much space it takes up in the runner.
                      awesome thanks man I now have an addition to my weekend projects
                      '89 L Charcoal
                      '89 L Red
                      '91 Ranger
                      '65 F100
                      Sepmer Fi
