So I have no dome light! I do have the wire, and the connector is bad, I can plug the tester in and ground it and it works but only if it goes through and touches the wires. So first I will strip this out and make a new connection, but I want to put LED's in. And I want to cover the whole up with some type of a switch. I don't want an ugly switch inside because it would be ugly. LOL so do youo have any ideas of what type of switches? any pictures? Have any of you dont this? I am not to worried about making it come one when the door is open, so it does not need to be connected to any switch's there in. So this wire works just fine for me. So how else would you wire it beside a switch? I am open to ideas. I am also looking to be as cheap as possible. But I want it done so i will spend money if I have too
Thanks
Thanks
