Cracked block
  • Cracked block
    I just put a bunch into this engine and am looking for a block but I'm broke, so short of another engine what repairs can I do to it?
    I was thinking JB weld but my dad's coworker said it would burn off and to use high temp plastic epoxy
    bubble gum, if you pay my boys to install it I GURANTEE it won't come off!
    I'd try the JB first, if it fails try the epoxy lol.. I've used JB weld on exhausts before, just don't know how well it would stick to the block.
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      If you go for the JB, make sure that block is spotless where you use it.
      Going old school...
        If you know a good local welder or diesel mechanic they can stitch weld the block. This is a common fix for Cummins 53 model blocks. Not as cheap buy if it hold up on diesels then it should on a festy
        Sent from Kingston Ga from my hillbilly handheld
        90 festy with 92 FI motor. Digital camo paint. BHAF. short throw. currently 47 MPGs
          where are you located bp?
          Rod
          "Confidence is the most important thing you can teach someone... if you can teach them confidence, you don't have to teach them anything else."
          1992 truckiva
          1989 festiva lx (mine again)
          1980 triumph tr7 convertible (project)
          1976 tr7 hardtop (parts car)
          1989 dodge caravan turbo
          1975 amc gremlin 4x4 (play toy)
            N. michigan- 49751
            Would I be able to use a mig welder on it?
              ^ no... not as such. welding would require high nickle wire and a BUTT load of pre heating
                Once upon a time people would drill and tap numerous times with the next hole slightly overlapping the
                previously drilled and tapped hole. A small NPT (1/8" which is probably not at your hardware store) size
                might work...each one would be drilled, tapped, plug inserted, ground flush and on to the next one. If it
                leaked any block sealer would fix it.......
                1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
                1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
